Введение
Is your LCD cracked or not working properly? Use this guide to help replace it, and return your GoPro to tip top shape!
Выберете то, что вам нужно
Pull the tab on the back of the device to release the back cover. It should come right off.
Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
Remove the image sensor from the motherboard assembly.
Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
The microSD/accessory board is ready to come off.
Using your trusty screwdriver, remove the single 3.2mm PH00 screw connecting the motherboard to the midframe.
Use the spudger tool to disconnect the front LCD from the motherboard. Gently pull the ribbon cable out.
Gently pull the motherboard away from the midframe.
Now that you have removed the plastic midframe from the motherboard, nothing is standing in the way of the LCD!
Carefully remove the ribbon cable from the midframe. It is attached with glue, so a spudger tool (or a heat gun if it's stubborn) will be needed.
5 человек успешно провели ремонт по этому руководству.
7 Комментарии к руководству
Where did you buy the replacement from?
I got my one from AliExpress (https://www.aliexpress.com/store/product...).
Merci beaucoup, trés utile pour les pilotes de drones fpv!
Thanks a lot, very helpfull for drone racers!
Dose it work for the silver édition as well ?
Thanks for this! I will just add that there is no need to take off the image sensor and the microSD board. You can simply skip from Step 6 to Step 13 without removing the motherboard. I wasted a lot of effort and almost broke my GoPro doing Steps 6-13.
