Введение
Prereq guide for midframe removal. Although the midframe itself rarely needs to be replaced, it must be removed in order to replace other components.
Выберете то, что вам нужно
Turn off the device.
Prepare an iOpener to heat the edges of the display and soften the adhesive underneath. Alternatively, you may use a heat gun or a hair dryer.
For reference, the back of the display panel is shown at left. Note the narrow clearance between the side of the display unit and the OLED panel. (The bezels indicate this spacing on the front.)
Инструмент, используемый на этом этапе:Suction Handle$2.99
Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
You may need to apply more heat if this doesn't come up. Don't be impatient, this will take time. Once you can gently insert a tool in the gap, move on to the next step.
Insert an opening pick or a playing card into the gap between the chassis and the display assembly.
Begin to slide the opening pick around the edge of the display, cutting through the adhesive that secures it.
Инструмент, используемый на этом этапе:iFixit Opening Picks (Set of 6)$4.99
With the adhesive cut, slowly lift the display up from the top (the side with the speaker-grille cutout), carefully flip it over vertically toward the bottom of the device, and rest it on its face, as shown.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a T5 Torx driver to remove the two black 3.5 mm T5 screws securing the display cable connector bracket.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to remove the bracket that holds the display connector in place.
This is just a piece of metal, and should come up very easily. (The cable is removed in the next step.)
Use a T5 Torx driver to remove the nine 3.5 mm screws securing the midframe.
The midframe is held tightly in place by five clips. To release these clips, apply inward pressure with an opening tool as shown in the steps below.
Wedge an opening pick into the notch that is located at the bottom right corner of the phone.
Slide the opening pick up both sides of the device in the small space between the midframe and the rear case to release the clips holding it in place.
Use a spudger to pry the earpiece speaker cable connector straight up, disconnecting it from the motherboard.
Remove the mid-frame from the device.
3 человек успешно провели ремонт по этому руководству.
