Введение
The device's screen will not light up or display a proper image. The screen could be damaged and need replacing. See theTroubleshooting page for this device before tearing it down.
Выберете то, что вам нужно
Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
Remove the rubber feet on the bottom of the device to access all the screws.
Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
Gently remove the optical drive (CD reader) to more easily separate the base.
Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
Pry open the screen cover using an iFixit opening tool around the entire screen.
Unplug the cable connected to the screen located on the bottom.
The screen should come off and can be replaced.
2 участников успешно повторили данное руководство.
