Введение
This guide will show you how to find your RAM and how to remove it properly.
Выберете то, что вам нужно
Flip the device over and locate the battery compartment.
Slide the battery release latch on the left and right side until the battery is detached from its slot.
A noticeable pop will be heard when the battery is fully released.
Place the laptop on a clean, flat surface with the bottom side facing up.
Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
Removing the friction pads will reveal two more anchoring screws.
Ensure your computer is shut down.
Remove any power adapters and cords connected to the laptop body.
Turn the computer over so the bottom is facing up.
Follow our guide on how to remove the backcover.
Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
2 человек успешно провели ремонт по этому руководству.
