Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace the fan in your laptop.
Выберете то, что вам нужно
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
Unscrew all four screws connecting the heatsink to the motherboard.
After loosening all screws remove the heat sink and store it in a safe place.
After removing the heat sink, disconnect the cable connecting the fan to the motherboard.
