Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The USB port is the component that accepts the entry and removal of digital transfer.
Выберете то, что вам нужно
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
At both ends of the connector ribbon, unclip both connectors.
Gently remove the ribbon from the unlatched area.
