HP Chromebook 11 G5 DC Charging Port Replacement
Выберете то, что вам нужно
  1. HP Chromebook 11 G5 DC Charging Port Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 2, изображение 1 из 1
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 3, изображение 1 из 1
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 4, изображение 1 из 1
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 5, изображение 1 из 1
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 6, изображение 1 из 1
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 7, изображение 1 из 1
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 8, изображение 1 из 1
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 DC Charging Port Replacement, DC Charging Port: шаг 9, изображение 1 из 1
    • Disconnect the charging port cable from the motherboard using your finger or a spudger and gently pull it off.
  10. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 10, изображение 1 из 1
    • Remove the two screws from the hinge of the device using a Phillips #00 screwdriver.
    • Carefully lift the hinge up.
  11. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 11, изображение 1 из 1
    • Carefully lift the charging port cable with the hinge up to remove the DC charging port.
  12. HP Chromebook 11 G5 DC Charging Port Replacement: шаг 12, изображение 1 из 1
    • Carefully remove the DC charging port from the base using a spudger.
Заключение
2 участников успешно повторили данное руководство.
Salma Zitoun
Участник с: 01/14/20
367 Репутация
Автор 2 руководств
Команда
York University, Team S1-G3, Woodhouse Winter 2020 Участник York University, Team S1-G3, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G3
3 членов
Автор 5 руководств
2 Комментариев
I thought it was going to be a little bit more difficult than it was . I got it done in about 15-20 minutes. Thanks to this.
Maryann Charles - Ответить
Do you guys sell these replacement DC Ports or know where to find them? (I work for a school, but the students keep breaking things! I need, like, 25 of these… yep, it’s that bad. Even found a literal nest of cockroaches inside one of them. I still have the picture/video of it for the morbidly curious lol.)
Aaron Yamauchi - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 22
За всё время: 1,239
