Введение
This guide requires only two screws to be removed with Phillips head screwdriver. Once the panel is removed, the ram can easily be pulled out.
Выберете то, что вам нужно
Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
3 человек успешно провели ремонт по этому руководству.
