Введение
Remove the power button panel from above the keyboard.
Выберете то, что вам нужно
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Flip over the laptop to the top side, and open the laptop.
Slide the locking tabs down using a blue plastic opening tool or your fingernail.
Pull up on both sides of the black locking tab of the connector.
The keyboard should now be free of the computer.
Put a finger under each side of the plastic lock on the ribbon cable and pull up.
Using a flathead screwdriver, get under each plastic hinge cover until they pop.
Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
4 человек успешно провели ремонт по этому руководству.
