Введение
If your HP EliteBook 745 G2 has malfunctioned or you want to upgrade your hard drive to a more substantial capacity or an SSD drive, this guide will help you locate your hard drive in your device for replacement.
A hard disk drive is used to store data on your device. It can store files, documents, programs, images, music, and files needed by your operating system to run your computer correctly. This device supports HDDs with the following specifications - Interface: ATA-8, SATA 2.6, 3.0GB/s, Width: 70mm, and Height: 9.5mm. It can also support SSDs with the following specifications - Interface: SATA 3 (6GB/s), Width: 70 mm, Height: 7mm.
If your computer is starting to slow down, or is often freezing, it is quite possible that your hard drive is failing and needs replacement. If your device has low storage capacity for your files, documents, and programs, it might be time to upgrade your device’s hard drive. Follow instructions to find out how much storage your PC has. You can also follow this guide to resolve low disk space issues and errors.
Before using this guide, make sure to review the troubleshooting page - your Windows Operating System, malware or corrupted files could be the issue, not necessarily your hard drive. If you are experiencing any of these scenarios, it is crucial to back up your device BEFORE attempting to replace your hard drive.
The back casing of your device can be easily removed, as seen in step 2, by a simple slide locking mechanism. Therefore, no additional tools are required to complete this guide. However, a Portable Anti-Static Mat, Wrist Strap, and Grounding Cord are recommended to avoid electrostatic damage to your device and components.
Before beginning, make sure to power off your device entirely and disconnect from any external power source.
Выберете то, что вам нужно
Gently place the laptop down on a suitable workplace with the back of the laptop facing up
Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
The hard drive is located to the left of the battery. To remove the hard drive firmly pull to the right until the drive is free from its attachment port.
Еще один человек закончил это руководство.
