Введение
This replacement guide will help replace your old or damaged battery in your HP Pavilion 17-ak008cy. If your battery has any physical damage handle with caution incase of chemical leaking from your battery. Besides for that this is a safe process. Overall this process is straight forward an no background information is needed for this process.
Using your hands, push the two tabs inwards to release the battery.
Remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 человек успешно провели ремонт по этому руководству.
