Введение
This guide shows you how to replace the cooling fan in an HP Pavilion 17-g192dx laptop.
Cooling fans help keep devices cool, as the name implies, by circulating air to dissipate excess heat. However, cooling fans have an average lifespan of only 3-6 years, and that lifespan can be further shortened by a dusty environment. An old or damaged laptop cooling fan can cause serious issues, from lagging to system crashes to device damage. If you notice grinding noises coming from your laptop, a hotter-than-usual CPU temperature, and/or decreases in system performance, it may be time to replace your cooling fan.
This replacement is relatively fast and easy, though it does require knowledge of How to Apply Thermal Paste. This is because the cooling fan is located on the motherboard and is connected to the heat sink; any time you remove a laptop's heat sink, you must reapply thermal paste during reassembly.
Lastly, ensure your laptop is powered down before you begin your repair.
Выберете то, что вам нужно
Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
Using a metal spudger, lift up on the back resting plate until it pops off.
Pry up on the case with an iFixit opening tool until you can feel a snap.
Pry around the remainder until you can separate the case from the keyboard with your hands.
Gently separate the two.
Remove the four 2mm screws on the heat sink with a Phillips #00 screwdriver.
Remove the heat sink.
When reinstalling the heat sink, be sure to clean the contact surfaces and reapply fresh thermal paste.
Remove the two 5mm screws holding the fan in place using the Phillips #00 screwdriver.
