Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Lost or wore out some of your keys? This guide will help you replace the keyboard on your laptop.
Выберете то, что вам нужно
The battery is held in by a latch in the front and tabs in the back.
Slide the lock switch left, towards the center of the computer.
Lift up the battery, rotating it up and away from you, then pull it out.
Unscrew one Phillips #1 screw from the back panel.
Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop.
8 участников успешно повторили данное руководство.
3 Комментариев
No hay información
Good guide. It helped me going quicker at getting to the keyboard. Thank you!
The keyboard for this computer is HP part number 640208-001 and it is not available anymore in HP. It is available in Amazon, however.
