Введение
If your computer keeps turning off, your battery may be damaged. Click here for more information on why your computer may be turning off.
Выберете то, что вам нужно
Flip over the laptop.
Unscrew the back cover using the Phillips #0 screwdriver.
Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
Carefully disconnect the three connectors by pulling them away from the slot.
Pull out the battery after everything is disconnected.
