Введение
Screen Replacement
- If your device screen on the HP Star Wars Special Edition 15-an051dx is not displaying any output follow this guide to help facilitate the process of replacing your screen.
- After powering your device and there is no output on your screen make the necessary changes with the steps shown below.
- Ensure you have powered off your device completely and disconnected any external power source.
- Gather the necessary tools shown in the tools section and begin your disassembling process.
Выберете то, что вам нужно
Remove the two circular plastic screw covers, then remove the two 4.5 mm screws in the using a Phillips #1 screwdriver.
Insert a spudger in between the bezel and display, at the top.
Move the tool around all sides of the bezel.
With your finger, lift the inside part of the bezel.
Pull the bezel back; it will pop-off.
Remove the four 2.75 mm screws using a Phillips #1 screwdriver
Lift the screen using a spudger.
Lifting the tape on the back of the screen and peel it off.
Remove the connection.
Enjoy your new screen!
2 человек успешно провели ремонт по этому руководству.
