HP ZBook 15 Fan and Heatsink Replacement
Выберете то, что вам нужно
  1. HP ZBook 15 Fan and Heatsink Replacement, Battery: шаг 1, изображение 1 из 2 HP ZBook 15 Fan and Heatsink Replacement, Battery: шаг 1, изображение 2 из 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Fan and Heatsink Replacement, Back Cover: шаг 2, изображение 1 из 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Fan and Heatsink Replacement, Keyboard: шаг 3, изображение 1 из 1
    • Remove the two 16mm screws with a Phillips #0 screwdriver.
    • There are two sets of threads to get past. Once unscrewed from the first thread, lift the screw up until it hits the next set and begin unscrewing again.
  4. HP ZBook 15 Fan and Heatsink Replacement: шаг 4, изображение 1 из 3 HP ZBook 15 Fan and Heatsink Replacement: шаг 4, изображение 2 из 3 HP ZBook 15 Fan and Heatsink Replacement: шаг 4, изображение 3 из 3
    • Do not try to pry the keyboard from the bottom. The keyboard is attached by clips on the left, top, and right side. Metal inserts on the bottom side lock the keyboard in place until they are slid up and out.
    • Be careful not to scratch or chip the computer when prying. If you have a plastic tool that is long enough to gain leverage, use that instead of a metal tool.
    • There are ribbons secured underneath so be careful not to pull the keyboard out too hard, breaking the connections to the ribbons.
    • Flip the laptop over so the keyboard is visible.
    • Insert the spudger under the left side of the keyboard.
    • Carefully raise the side of the keyboard and firmly pull the left corner of the keyboard until it pops up.
    • Run your fingers under the edges of the keyboard along the top edge of the keyboard, from the top left to the top right, to separate it from the remaining clips.
    • Carefully slide the keyboard up toward the screen and out of the case.
  5. HP ZBook 15 Fan and Heatsink Replacement: шаг 5, изображение 1 из 3 HP ZBook 15 Fan and Heatsink Replacement: шаг 5, изображение 2 из 3 HP ZBook 15 Fan and Heatsink Replacement: шаг 5, изображение 3 из 3
    • Gently lift the two tabs on either side of the black ribbon with a spudger until the ribbon comes loose.
    • Disconnect the black ribbon by pulling the blue tab hanging off of it.
    • Repeat with the white ribbon.
  6. HP ZBook 15 Fan and Heatsink Replacement, Optical Drive: шаг 6, изображение 1 из 1
    • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
    • The screw does not come out all the way and stays attached to the computer.
  7. HP ZBook 15 Fan and Heatsink Replacement: шаг 7, изображение 1 из 3 HP ZBook 15 Fan and Heatsink Replacement: шаг 7, изображение 2 из 3 HP ZBook 15 Fan and Heatsink Replacement: шаг 7, изображение 3 из 3
    • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
    • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
  8. HP ZBook 15 Fan and Heatsink Replacement, HP ZBook 15 Hard Drive Disassembly: шаг 8, изображение 1 из 1
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
  9. HP ZBook 15 Fan and Heatsink Replacement: шаг 9, изображение 1 из 2 HP ZBook 15 Fan and Heatsink Replacement: шаг 9, изображение 2 из 2
    • Pull the green tab away from the metal casing and lift the drive out.
  10. HP ZBook 15 Fan and Heatsink Replacement, Fan and Heatsink: шаг 10, изображение 1 из 1
    • Unscrew two 3mm screws from the hard drive bay with a Phillips #0 screwdriver.
  11. HP ZBook 15 Fan and Heatsink Replacement: шаг 11, изображение 1 из 1
    • Remove the eight 6mm screws with a T8 Torx screwdriver.
  12. HP ZBook 15 Fan and Heatsink Replacement: шаг 12, изображение 1 из 1
    • Rotate the laptop so the battery compartment is in front of you.
    • Remove the four 4 mm screws under the battery with a T8 Torx screwdriver.
  13. HP ZBook 15 Fan and Heatsink Replacement: шаг 13, изображение 1 из 1
    • Remove three more 4mm screws from the optical drive compartment with a T8 Torx screwdriver.
  14. HP ZBook 15 Fan and Heatsink Replacement: шаг 14, изображение 1 из 1
    • Flip the laptop so it is keyboard side up.
    • Remove the 6mm screw with a T8 Torx screwdriver.
  15. HP ZBook 15 Fan and Heatsink Replacement: шаг 15, изображение 1 из 1
    • Use a spudger to lift the edges of the connector up so the white ribbon can slide out.
    • Pull the ribbons out by the blue plastic tab on the cable at each connector site.
  16. HP ZBook 15 Fan and Heatsink Replacement: шаг 16, изображение 1 из 1
    • There are still ribbons that need to be removed before the top cover separates completely; do not yank the cover off after it is separated to prevent ripping the cables out.
    • Start at the front of the latop and run a plastic spudger between the top cover and the case to undo the clips holding it together
    • If there is difficulty separating the top cover from the computer, do not force it. You might have missed a screw.
  17. HP ZBook 15 Fan and Heatsink Replacement: шаг 17, изображение 1 из 2 HP ZBook 15 Fan and Heatsink Replacement: шаг 17, изображение 2 из 2
    • Angle the top cover so you can see the white ribbons shown in the picture.
    • Carefully slide the top cover toward you to expose the white ribbon connectors.
    • Use a spudger to lift the connectors and slide out both ribbons.
  18. HP ZBook 15 Fan and Heatsink Replacement: шаг 18, изображение 1 из 1
    • Unscrew the eight captive screws with a T9 Torx screwdriver.
    • Undo the screws in the order represented by the small numbers next to the screw on the heat sink assembly. Repeat this while reassembling to prevent damage to the components underneath.
    • These screws will also not unscrew all the way.
  19. HP ZBook 15 Fan and Heatsink Replacement: шаг 19, изображение 1 из 1
    • Gently pull up on the 4 pin fan power connector cable to unplug it from the system.
  20. HP ZBook 15 Fan and Heatsink Replacement: шаг 20, изображение 1 из 1
    • Gently lift the fan and heatsink assembly straight up and out so you do not smear the thermal paste.
    • Thermal paste is a heat conductive gel applied to the underside of the heatsinks. Be careful not to wipe any off or else the components within the laptop will not cool properly and could become damaged. It also makes a big sticky mess if it smears or gets on any other components.
Заключение
14 участников успешно повторили данное руководство.
Grant Terris
Участник с: 01/30/15
2 828 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 8-43, Amido Winter 2015 Участник Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 членов
Автор 15 руководств
6 Комментариев
Wow, looks like that graphics card is actually user replaceable? That’s really awesome to see, with both the CPU being socketed and GPU being on a slot, that makes this system super upgradable and (hopefully) long lasting. If you manage to burn your GPU out, you don’t have to replace the entire motherboard.
Shane Roeseberg - Ответить
I performed this procedure to replace the fan/heatsink assembly, and used the HP maintenance and service guide for this machine which can be found at http://h10032.www1.hp.com/ctg/Manual/c03... - it differs from these instructions (an improvement) is two ways - first, the optical drive should be removed before the keyboard, and then the keyboard can be pushed up from below to get it started, which is much better than forcing the whole thing from above. Secondly, removal of the top cover does not start with separating the front edge as these instructions show, but by lifting the back edge and then sliding the cover forward, which takes very little force. The Ifixit instructions were a good start, but I was glad I had the real stuff from HP.
Steve Reynolds - Ответить
What about electrostatic discharge though? How does it fit into the picture, and how does one protect against it?
croassassinvk - Ответить
I did this in order to clean up the innards and apply thermal paste. I gotta say it’s a hastle compared to the older EliteBooks where all you had to do to access the CPU was to open the service door/cover.
But eh, what can you do, right?
Luis Alejandro Araúz - Ответить
Great write up. However, these copper pipe type coolers don’t fail unless you’ve busted the fan somehow. For those of you with this overheating problem, just take it apart and put new thermal paste in there.
My 6yr old machine was overheating badly, and would BSOD on occasion. A quick look with hwinfo revealed a cpu that was hitting 100°C.
Too hot!
I blew in the vents with some light compressed air and this blew out a small slug of lint.
Didn’t help much.
Ran Aida64 FPU and it would immediately overheat and throttle
I went by the pics on here and knew that my fan was operating normally so I figured I’d try new paste before dropping $50+ on a new fan.
Pulled the heatsinks out, put some new Artic Silver on there and put it back together.
Now even under Aida64 FPU it’s only hitting 93°C now and no throttling.
Robin Oury - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 38
За последние 30 дней: 142
За всё время: 29,033
