Введение
This guide will take you through the process of replacing the speakers for the HTC One Remix.
Выберете то, что вам нужно
Use the sim eject tool to remove the SIM cards on either side of the phone.
Place the warm iOpener on the top of the phone for three minutes.
Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
Remove the single 3 mm screw that is on the top left side using a Torx 4 screwdriver.
Use the plastic prying tool to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone.
With tweezers, remove the small pieces of yellow tape that cover the zif connectors.
Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper plate.
With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it.
Use tweezers to carefully detach the eight ribbon cables from the connectors.
Remove the two 1 mm screws at the bottom right of the motherboard using a Torx 4 screwdriver.
Pull off one end of each of the five colored connecting cables from the motherboard.
Pull the black and red wire from the motherboard on the bottom left.
Remove the four 3 mm screws on each corner of the motherboard using a Torx 4 screwdriver.
Gently lift the motherboard out of the phone using the plastic opening tool.
With a plastic opening tool, remove the black speaker at the bottom of the phone.
Remove the gold tape at the top right corner of the phone and disconnect the ribbon wire from the circuit board.
Remove the four 1mm screws on the circuit board using a Phillips #00 screwdriver.
Remove the circuit board.
