Введение
This guide provides step-by-step instructions for replacing the headphone jack on the HTC One S. Intermediate soldering skills are required to remove the component.
Инструменты
Запчасти
Детали не указаны.
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Handling it by the tag, place the heated iOpener across the bottom casing.
Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing.
Remove the following screws holding the rear case to the rest of the phone:
Two 3.15 mm Phillips #00 screws
One 4.15 Torx T5 screw
One 4 mm Torx T5 screw
Place your fingers on either side of the phone and gently push up on the rear case.
Using the pointed end of a spudger, lift the battery cable and release the connector.
Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive.
Remove the three 3.15mm Phillips #00 screws from the turquoise case.
Using a plastic opening tool, lift the turquoise case from the end near the headphone jack.
Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector.
Repeat the procedure from steps 19 and 20 to remove the cables from the remaining ZIF connectors.
Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard.
Using tweezers, remove the adhesive tape around the headphone jack.
Using a soldering iron set at 400 degrees Celsius (752 degrees Fahrenheit), heat the solder joints lateral to the headphone jack. Use a pair of tweezers to lift the headphone jack from the board.
