Введение
Use this guide to remove and replace the focus knob on an HTC Vive.
Выберете то, что вам нужно
Use tweezers to remove the small stickers over the four screws securing the outer shell.
Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
Grasp the right half the outer shell and pull it to the right and toward the front of the headset until you feel the clips on the front of the cover release.
If the shell is difficult to remove, try prying along the seam with the flat end of a spudger to release the clips.
Use a PH000 driver to remove the screw securing the focus knob.
Еще один человек закончил это руководство.
