Введение
Use this guide to remove and replace the head strap mounts on an HTC Vive.
Выберете то, что вам нужно
Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
Pull the rubberized grip off of the head strap mount.
Repeat the previous three steps with the right head strap mount to remove it and separate its components.
2 участников успешно повторили данное руководство.
5 Комментариев
how do you pute the headset back to getther on the vive.
how do you put the strape back on the right way im stuk i need some help with it.
same man, my headstrap mount and a tracker dongle broke and theres no way to replace it. fml
