Введение
This page will guide you through the replacement of the motor block in your Hamilton Beach Classic Stand Mixer 64650. You may also find this guide useful to access many other parts in your mixer that you may be experiencing problems with. Although this guide will require the use of a soldering iron, there is a link provided to walk through the process step-by-step.
Выберете то, что вам нужно
Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
Carefully pull the motor block out of the case.
Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
