Введение
Having problems with audio? Your speaker might not be working well! Read this guide to find out how you can fix that! :)
Выберете то, что вам нужно
After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
Increase the degree of slant until the back cover is completely removed.
After removing the back cover, you will see 3 screws: one 7mm Phillips #0 screw at the top and two 11mm Phillips #0 screws at the bottom.
Use a screwdriver to remove all 3 screws.
Use a screwdriver to remove the three 7mm Phillips #0 screws holding the speaker in place.
Gently pull out the speaker and inspect it.
Determine if the handset speaker is damaged and needs replaced. Replacement requires soldering.
Finish removing a faulty speaker by cutting the two wires connecting it to the circuit board.
Solder your replacement speaker into the circuit. For assistance with soldering refer to iFixit Solder and Desolder Guide.
Solder the replacement speaker in the circuit board. For information on how-to-solder check iFixit's Solder and Desolder Guide by clicking the blue link below.
