Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
To replace the speaker the tools you will need are tweezers and a #00 Philips screwdriver.
Выберете то, что вам нужно
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Remove the four 2.6 mm Philips screws that are on the sides of the frame.
Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
Use tweezers to pull speaker off.
Pull speaker off by wire, pull down away from screen.
