Введение
This guide involves the manipulation of small, intricate parts. Please use caution.
Before disassembling your device, please refer to the troubleshooting guide to investigate other possible solutions to your problem.
Выберете то, что вам нужно
Remove the front two hub caps.
When finished, you should be able to remove the back cover.
Pry the perimeter of the case open with the plastic opening tool.
Remove the back panel.
Unscrew all of the screws that you can access on the hard drive.
If you cannot reach the screw beneath the black strip, move on to the next step.
Using the tweezers, carefully remove the latches attaching the silver computer chip.
Еще один человек закончил это руководство.
