Введение
After extended use, the speakers might lose sound quality and require replacement.
Выберете то, что вам нужно
Remove the back cover of the device using a combination of both plastic opening tools.
Use your plastic opening tool to pry open a corner of the device. Continue using the tool down the side of the device to open it completely.
Use a Phillips head #00 screwdriver to remove the two 4.43mm screws on the bottom that keep the speakers in place.
Unsolder the red and black wires connecting the speaker to the motherboard. Take a look at this guide to learn how to solder and unsolder connections.
Еще один человек закончил это руководство.
