Введение
This guide shows how to remove and replace the air filters on the Honda EU2200IT generator.
Выберете то, что вам нужно
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a Phillips #2 screwdriver to loosen the screw holding the maintenance cover in place.
Remove the air filters from the filter box.
Clean the filters in warm soapy water.
Allow the filters to dry thoroughly.
Dip the filters in clean engine oil, and squeeze out any excess oil.
