Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
Unplug the battery by pulling apart the yellow connectors.
Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
Unplug the green wires by gripping the wire close to the connectors and pulling apart.
Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
Unplug the rainbow connector by squeezing the clips and pulling apart.
Use scissors to cut the zip tie around the group of wires.
Unplug the white wire connector by squeezing the clips and pulling apart.
Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
Pull out the loosened screws with your hands and remove the metal plate.
3 участников успешно повторили данное руководство.
