Введение
Use this guide to replace the adhesive underneath the power button board and the interconnect cable in your Kobo Libra Colour eReader.
Выберете то, что вам нужно
Apply a few drops of isopropyl alcohol (>90%) to the power button board's spot on the frame.
Use a spudger to scrape off the adhesive residue.
Use a coffee filter or a lint-free cloth to wipe down the spot.
Repeat the same adhesive removal procedure for the remaining adhesive at the interconnect cable's spot on the frame.
Wait for the frame to dry completely before continuing.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$2.99
Peel the power button board adhesive strip off its yellow liner to expose the adhesive underneath.
Apply the adhesive strip—sticky side down—to its spot on the frame, making sure it's aligned properly around the alignment pegs.
Use the flat end of a spudger, or your finger, to press down the adhesive strip and adhere it.
Peel off the white liner to expose the top adhesive.
Repeat the same adhesive application procedure for the interconnect cable adhesive strip.
Reconnect the interconnect cable to the power button board.
Place the power button board on its spot on the frame, making sure it sits properly on its alignment pegs.
Use the flat end of a spudger, or your finger, to press down the power button board and adhere it.
Reconnect the interconnect cable to the motherboard.
Use your finger to press the cable onto its adhesive and adhere it to the frame.
Return to the original guide and continue reassembly, skipping steps you did for this procedure.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
