Введение
This guide shows how to change the engine oil for the Honda EU2200IT generator. This procedure is a prerequisite for many other repairs.
Oil specifications:
SAE 10W-30
0.46 US quarts (0.44 L)
Выберете то, что вам нужно
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a Phillips #2 screwdriver to loosen the screw holding the maintenance cover in place.
Place an oil pan below the fill port to catch the engine oil.
Carefully tilt the generator towards the oil pan to drain the oil.
Еще один человек закончил это руководство.
