How to Clean Up Solder Pads
Выберете то, что вам нужно
  1. How to Clean Up Solder Pads, Equipment and supplies: шаг 1, изображение 1 из 1
    • The materials needed for this are a soldering iron, soldering paste and desoldering wire, also known as a wick.
    • The soldering paste helps the solder flow into the wick better. If you don't have soldering paste, you can get similar results with flux.
  2. How to Clean Up Solder Pads, Prep the area: шаг 2, изображение 1 из 1
    • There are many types of soldering paste—many of which are in a syringe-like tube, which makes it easy to get the paste in the exact spot it needs to be.
    • I personally use a plastic opening tool to scoop a little out and apply it gently on the spot I will be working on.
    • If you don't have soldering paste, apply some flux to the spot you're working on.
  3. How to Clean Up Solder Pads: шаг 3, изображение 1 из 1
    • The location I will be de-soldering is right above the SPK location in the photo.
    • If you're de-soldering battery connections, be very careful not to short the contacts with your soldering iron or the solder wick. If possible, cut the battery wires first, one at a time. This removes the chance of accidentally shorting the battery.
  4. How to Clean Up Solder Pads, Heat the solder joint: шаг 4, изображение 1 из 2 How to Clean Up Solder Pads, Heat the solder joint: шаг 4, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    FixHub Smart Soldering Iron
    $79.95
    • Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder.
    • Lift the wick and the soldering iron up from the logic board at the same time. Failure to do so can cause the leftover solder to harden and solder the wick to the logic board and you could easily pull a logic board pad off.
    • Please remember that logic board components are very fragile and excessive heat can destroy these components.
  5. How to Clean Up Solder Pads: шаг 5, изображение 1 из 1
    • What’s left over is clean points on the solder board, ready for fresh solder.
Заключение
For more soldering guides and tips, check out this page.
96 человек успешно провели ремонт по этому руководству.
Romin McGowan
Участник с: 04/29/13
4 004 Репутация
1 руководство автора
1 Комментарий к руководству
Well Explained
Muhamamd Asif - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 17
За последние 7 дней: 97
За последние 30 дней: 369
За всё время: 25,241
