How to Fix a Broken XLR Microphone Cable
Выберете то, что вам нужно
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: шаг 1, изображение 1 из 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: шаг 1, изображение 2 из 3 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: шаг 1, изображение 3 из 3
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: шаг 2, изображение 1 из 1
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: шаг 3, изображение 1 из 2 How to Fix a Broken XLR Microphone Cable: шаг 3, изображение 2 из 2
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: шаг 4, изображение 1 из 3 How to Fix a Broken XLR Microphone Cable: шаг 4, изображение 2 из 3 How to Fix a Broken XLR Microphone Cable: шаг 4, изображение 3 из 3
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: шаг 5, изображение 1 из 2 How to Fix a Broken XLR Microphone Cable: шаг 5, изображение 2 из 2
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
Заключение
4 участников успешно повторили данное руководство.
Abbie Zajac
Участник с: 01/19/16
203 Репутация
1 руководство автора
Команда
Oakland University, Team 6-3, Walwema Winter 2016 Участник Oakland University, Team 6-3, Walwema Winter 2016
OAK-WALWEMA-W16S6G3
2 членов
Автор 2 руководств
Один комментарий
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 26
За последние 30 дней: 152
За всё время: 25,024
