How to Fix a Stuck Button in Sharp Calculator
Выберете то, что вам нужно
  1. How to Fix a Stuck Button in Sharp Calculator, Button Keys: шаг 1, изображение 1 из 1
    • Turn the power off by pressing a button named 2NDF located in the top-left corner.
    • Press the button named ON/C in the top-right corner.
  2. How to Fix a Stuck Button in Sharp Calculator: шаг 2, изображение 1 из 2 How to Fix a Stuck Button in Sharp Calculator: шаг 2, изображение 2 из 2
    • Flip the calculator over so that the back panel is facing upwards.
    • Remove two 5mm Phillips #0 screws from the battery cover by turning the screwdriver in a counter-clockwise direction.
    • Remove the remaining four 5mm Phillips #0 screws from the back panel cover.
  3. How to Fix a Stuck Button in Sharp Calculator: шаг 3, изображение 1 из 1
    • Remove the battery cover.
    • Insert a spudger into the slot located in the top-right corner and pry the battery out.
  4. How to Fix a Stuck Button in Sharp Calculator: шаг 4, изображение 1 из 1
    • Remove the front panel by sticking an opening tool into a small gap between front and back panel.
    • Push the tool down with force and pry open the right side carefully.
    • Detach the front panel from the back panel by lifting the front board.
    • Separate the front and back panel slowly to avoid damaging the LCD ribbon.
  5. How to Fix a Stuck Button in Sharp Calculator: шаг 5, изображение 1 из 1
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws from the motherboard.
  6. How to Fix a Stuck Button in Sharp Calculator: шаг 6, изображение 1 из 2 How to Fix a Stuck Button in Sharp Calculator: шаг 6, изображение 2 из 2
    • Lift the motherboard by holding both sides and placing it on the top panel.
    • Lift the grey padding upwards by holding any corner and place it on top of the motherboard.
    • Press the grey padding and put pressure downward to avoid sticking from physical buttons.
  7. How to Fix a Stuck Button in Sharp Calculator: шаг 7, изображение 1 из 2 How to Fix a Stuck Button in Sharp Calculator: шаг 7, изображение 2 из 2
    • Use a spudger to flip, remove, and adjust the position of buttons.
    • Ensure the placement of buttons is correct. Use STEP 1 Image as a reference to the location of buttons.
Заключение
2 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
Micah Bustamante
Участник с: 05/08/20
169 Репутация
1 руководство автора
Команда
York University, Team S1-G5, O'Regan Summer 2020 Участник York University, Team S1-G5, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G5
1 член
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 28
За всё время: 5,427
