How to Install a Heatsink on an M.2 SSD
Выберете то, что вам нужно
  1. How to Install a Heatsink on an M.2 SSD, Prepare the first thermal pad: шаг 1, изображение 1 из 1
    • The heatsink uses thermal pads to dissipate heat from either side of the blade SSD. The thermal pads may come with plastic liners on each side, so make sure all are removed before use.
    • Use a pair of tweezers to peel one side of protective film away from one of the thermal pads.
  2. How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: шаг 2, изображение 1 из 3 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: шаг 2, изображение 2 из 3 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: шаг 2, изображение 3 из 3
    • Align the exposed side of the thermal pad with the bottom tray section of the heatsink assembly.
    • Lay the thermal pad down so it covers the tray evenly.
    • Use your finger to lightly press down on the thermal pad to adhere it to the surface.
  3. How to Install a Heatsink on an M.2 SSD, Prepare the second thermal pad: шаг 3, изображение 1 из 1
    • Use a pair of tweezers to peel one side of protective film away from the remaining thermal pad.
  4. How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: шаг 4, изображение 1 из 3 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: шаг 4, изображение 2 из 3 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: шаг 4, изображение 3 из 3
    • Align the exposed side of the thermal pad with the top section of the heatsink.
    • Lay the thermal pad down so it covers the top section evenly.
  5. How to Install a Heatsink on an M.2 SSD, Remove the bottom thermal pad liner: шаг 5, изображение 1 из 1
    • Use a pair of tweezers to remove the plastic liner from the thermal pad in the tray.
    • The thermal pad might lift up from the tray as the liner is removed—this is normal. Use your finger to keep the pad in the tray.
  6. How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: шаг 6, изображение 1 из 3 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: шаг 6, изображение 2 из 3 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: шаг 6, изображение 3 из 3
    • Lay the M.2 SSD into the tray, the side with the most chips facing up.
    • Make sure the SSD is centered in the tray. The tray shouldn't cover the contacts or the screw cutout.
  7. How to Install a Heatsink on an M.2 SSD, Remove the top thermal pad liner: шаг 7, изображение 1 из 1
    • Use a pair of tweezers to remove the plastic liner from the thermal pad on the heatsink's top section.
    • The thermal pad might lift up from the heatsink as the liner is removed—this is normal. Use your finger to keep the pad in place.
  8. How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: шаг 8, изображение 1 из 3 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: шаг 8, изображение 2 из 3 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: шаг 8, изображение 3 из 3
    • Align the top heatsink section over the SSD and the tray.
    • Firmly press the two halves together. You'll feel it "snap" into place.
  9. How to Install a Heatsink on an M.2 SSD, Check the alignment: шаг 9, изображение 1 из 1
    • For the SSD to fit in a desktop PC or a PlayStation 5, the heatsink needs to be centered on the SSD.
    • Make sure that the heatsink is close to the screw cutout but doesn't overhang it.
    • If you're having trouble installing your SSD, you may have to slightly adjust the heatsink's position.
    • Use your fingers to slide the SSD between the two halves of the heatsink assembly until fitment is just right.
Заключение
Installation didn’t go as planned? Check out our Computer Hardware Answers community or PlayStation 5 Answers community for troubleshooting help.
7 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
113 751 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 820 руководств
2 Комментариев
If your SSD has a big "warranty void if removed" sticker over the chips, do you have to remove it? Or can you stick the thermal pad over that sticker?
shamino - Ответить
You can leave the sticker on the SSD! Just make sure to remove any adhesive liners on the thermal pad.
Carsten Frauenheim -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 57
За последние 7 дней: 343
За последние 30 дней: 1,543
За всё время: 42,454
