How to Make an Affordable Soldering Fume Extractor
Выберете то, что вам нужно
  1. How to Make an Affordable Soldering Fume Extractor, Overview: шаг 1, изображение 1 из 2 How to Make an Affordable Soldering Fume Extractor, Overview: шаг 1, изображение 2 из 2
    • This fume extractor is composed of three main parts: a 12V computer fan, cardboard box enclosure, and activated carbon filter.
    • Solder often contains rosin flux. When vaporized during soldering, it's a respiratory and eye irritant and can cause health issues when inhaled long term.
    • This extractor pulls the harmful fumes into the charcoal filter trapping volatile compounds, removing them from the air.
  2. How to Make an Affordable Soldering Fume Extractor, Position the fan on the box: шаг 2, изображение 1 из 1
    • Position the fan over the box so that an exhaust cutout can be made.
  3. How to Make an Affordable Soldering Fume Extractor, Poke fan mounting holes: шаг 3, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Poke fan mounting holes: шаг 3, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Poke fan mounting holes: шаг 3, изображение 3 из 3
    • Use a pointy object like a screwdriver to poke four fan mounting holes into the box.
  4. How to Make an Affordable Soldering Fume Extractor, Trace the inside diameter of the fan onto the box: шаг 4, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Trace the inside diameter of the fan onto the box: шаг 4, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Trace the inside diameter of the fan onto the box: шаг 4, изображение 3 из 3
    • Use a pen or pencil to mark the inside diameter of the fan onto the box.
  5. How to Make an Affordable Soldering Fume Extractor, Cut out the exhaust port: шаг 5, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Cut out the exhaust port: шаг 5, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Cut out the exhaust port: шаг 5, изображение 3 из 3
    • Use a razor blade to cut out the fan exhaust port.
  6. How to Make an Affordable Soldering Fume Extractor, Poke four more fan mounting holes: шаг 6, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Poke four more fan mounting holes: шаг 6, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Poke four more fan mounting holes: шаг 6, изображение 3 из 3
    • Poke four more holes about 1 cm out from the ones you made earlier.
  7. How to Make an Affordable Soldering Fume Extractor, Mark the intake port: шаг 7, изображение 1 из 2 How to Make an Affordable Soldering Fume Extractor, Mark the intake port: шаг 7, изображение 2 из 2
    • Flip the box over.
    • Use a pen or a pencil and a straight edge to mark out the intake port.
    • Leave a lip so the filter material won't fall out when placed inside the box.
  8. How to Make an Affordable Soldering Fume Extractor, Cut out the intake port: шаг 8, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Cut out the intake port: шаг 8, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Cut out the intake port: шаг 8, изображение 3 из 3
    • Use a razor blade to cut out the intake port in the box.
  9. How to Make an Affordable Soldering Fume Extractor, Thread zip ties through the fan mount holes: шаг 9, изображение 1 из 1
    • Thread four zip ties through the fan mounting holes.
  10. How to Make an Affordable Soldering Fume Extractor, Cut the filter to size: шаг 10, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Cut the filter to size: шаг 10, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Cut the filter to size: шаг 10, изображение 3 из 3
    • Activated carbon filters come in all shapes and sizes. You may need to cut and modify the filter to fit your enclosure.
    • Cut the filter so it will fit snugly in the intake port.
  11. How to Make an Affordable Soldering Fume Extractor, Insert the filter into the intake port: шаг 11, изображение 1 из 2 How to Make an Affordable Soldering Fume Extractor, Insert the filter into the intake port: шаг 11, изображение 2 из 2
    • Insert the filter into the intake port.
    • If your filter doesn't span the intake port, you can use glue or tape to connect multiple filter sections together.
  12. How to Make an Affordable Soldering Fume Extractor, Secure the fan to the exhaust port: шаг 12, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Secure the fan to the exhaust port: шаг 12, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Secure the fan to the exhaust port: шаг 12, изображение 3 из 3
    • Thread the zip ties through the fan's mounting holes.
    • Make sure the fan's intake side is placed against the box hole, or you'll end up with a soldering fume blower.
    • Secure the fan to the exhaust port by tightening the zip ties.
    • Clip the excess zip tie strap.
  13. How to Make an Affordable Soldering Fume Extractor, Cut off the fan connector: шаг 13, изображение 1 из 2 How to Make an Affordable Soldering Fume Extractor, Cut off the fan connector: шаг 13, изображение 2 из 2
  14. How to Make an Affordable Soldering Fume Extractor, Thread the fan cable into the box: шаг 14, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Thread the fan cable into the box: шаг 14, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Thread the fan cable into the box: шаг 14, изображение 3 из 3
    • Use a pointy object like a screwdriver to poke a hole in the box for the fan cable.
    • Thread the fan cable into the box.
  15. How to Make an Affordable Soldering Fume Extractor, Cut out a hole for the switch: шаг 15, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Cut out a hole for the switch: шаг 15, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Cut out a hole for the switch: шаг 15, изображение 3 из 3
    • Use a pen or pencil to mark the outline of the switch.
    • Choose a convenient and easily accessible location.
    • Cut out a hole for the switch.
    • Pull the fan cable through the switch hole.
  16. How to Make an Affordable Soldering Fume Extractor, Wire up the fan, switch, and battery: шаг 16, изображение 1 из 3 How to Make an Affordable Soldering Fume Extractor, Wire up the fan, switch, and battery: шаг 16, изображение 2 из 3 How to Make an Affordable Soldering Fume Extractor, Wire up the fan, switch, and battery: шаг 16, изображение 3 из 3
    • Before soldering, make sure the fan is wired up correctly. If the positive and negative wires are switched, the fan might burn out.
    • Solder the switch between the fan's positive wire and the battery's positive wire.
    • Solder the negative fan wire to the negative battery wire.
    • Pull the excess cable back through and mount the switch to the box.
  17. How to Make an Affordable Soldering Fume Extractor, Place the electronics in the box: шаг 17, изображение 1 из 1
    • Place the loose wires in the box.
    • Secure the 9V battery to the interior of the box using double sided tape.
  18. How to Make an Affordable Soldering Fume Extractor, Admire your creation: шаг 18, изображение 1 из 2 How to Make an Affordable Soldering Fume Extractor, Admire your creation: шаг 18, изображение 2 из 2
    • Rejoice! The days of holding your breath or inhaling solder fumes are over.
    • If your solder fumes are especially potent and are visible in the exhaust, you can stack additional filter material to trap them.
Заключение
Now that you've created a fume extractor, check out some of our soldering guides or stop by our store for supplies you might need on your soldering journey.
27 человек успешно провели ремонт по этому руководству.
Chayton Ritter
Участник с: 08/21/20
22 518 Репутация
Автор 105 руководств
Команду
Guide Team Участник Guide Team
Staff
9 членов
Автор 11 420 руководств
11 Комментариев
Nice job. As for those 9 volt batteries, you will find that when your smoke alarm starts beeping, the batteries still have plenty of life left for running the fan. No need to buy a new battery.
Phil - Ответить
how long will the battery last? why not use a battery connector? so changing out the battery would be a lot easier.
Russell G Stewart - Ответить
they do, it's easiest to see in the step 1 photo, but it's also there in step 17
X2Brute -
Why not put the fan in the box?
Why not reduce the inlet opening to the size of a smoke filter and thus save a filter?
Simon Martel - Ответить
Why not indeed! I hear a v2 in the making :)
Shahram Mokhtari -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 36
За последние 7 дней: 273
За последние 30 дней: 1,412
За всё время: 17,403
