Введение
Use this guide to open your Logitech MX Anywhere 3 for Mac mouse.
Open your mouse to clean its internals, troubleshoot mechanical problems, or replace a part.
Выберете то, что вам нужно
Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
Heat an iOpener and apply it to the mouse feet for about two minutes.
There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
Инструмент, используемый на этом этапе:Tweezers$4.99
Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
Repeat to remove the three remaining mouse feet.
Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the two halves of the mouse together.
Gently open the top half of the mouse up and flip it over to the right, like a book.
Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
Еще один человек закончил это руководство.
