How to Open the SteelSeries Stratus Duo
Выберете то, что вам нужно
  1. How to Open the SteelSeries Stratus Duo, Remove the sticker: шаг 1, изображение 1 из 2 How to Open the SteelSeries Stratus Duo, Remove the sticker: шаг 1, изображение 2 из 2
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
  2. How to Open the SteelSeries Stratus Duo, Unscrew the back cover: шаг 2, изображение 1 из 1
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
  3. How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: шаг 3, изображение 1 из 3 How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: шаг 3, изображение 2 из 3 How to Open the SteelSeries Stratus Duo, Reposition the back cover assembly: шаг 3, изображение 3 из 3
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
  4. How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: шаг 4, изображение 1 из 3 How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: шаг 4, изображение 2 из 3 How to Open the SteelSeries Stratus Duo, Disconnect the interconnect cable: шаг 4, изображение 3 из 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
  5. How to Open the SteelSeries Stratus Duo: шаг 5, изображение 1 из 2 How to Open the SteelSeries Stratus Duo: шаг 5, изображение 2 из 2
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
  6. How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: шаг 6, изображение 1 из 3 How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: шаг 6, изображение 2 из 3 How to Open the SteelSeries Stratus Duo, Disconnect the battery cable: шаг 6, изображение 3 из 3
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
  7. How to Open the SteelSeries Stratus Duo, Remove the back cover assembly: шаг 7, изображение 1 из 1
    • Remove the back cover assembly.
Заключение
3 участников успешно повторили данное руководство.
Adriana Zwink
Участник с: 12/18/19
45 268 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Community
142 членов
Автор 16 235 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 19
За последние 30 дней: 73
За всё время: 1,393
