Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Measure top and bottom of damaged section.
Use a straight edge between the the top and bottom and draw a straight-line connecting the marking.
Mark with a pencil, or cut lightly with utility knife.
Using your putty knife, dig out of the spackle inside your marking.
Unscrew screws in the section of bead that you are going to remove.
Cut the metal corner bead with tin snips.
Measure new corner bead and cut.
Place new corner bead on corner and fasten in place using screws or tape.
Apply joint compound with a 4 inch putty knife.
Dry for 12 hours.
Sand area with 80 grit sandpaper.
Wipe down with damp cloth, sponge, or paper towel.
Apply thinner coat of joint compound with a 6, or 8 inch putty knife.
Let dry for 2 hours.
Sand the area with 120 grit sandpaper.
Paint the patched area to match wall
Еще один человек закончил это руководство.
