How to Repair LED Strip Lights
Выберете то, что вам нужно
  1. How to Repair LED Strip Lights, How to Repair LED Strip Lights: шаг 1, изображение 1 из 1
    • Find the spot where the lights stop working and where there are four connections labeled in descending order, "12V, R, G, B" with a scissor "cut here" marking and a copper colored backing.
  2. How to Repair LED Strip Lights: шаг 2, изображение 1 из 1
    • With a scissor, cut along the "cut here" line, separating the faulty strip from the working strip.
  3. How to Repair LED Strip Lights: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Align the new strip next to the working strip and keep them steady. Look at the four connections like a mirror image. R to R, G to G, etc.
    • Use a soldering iron to solder all four connections.
    • Make sure the solder is secured.
  4. How to Repair LED Strip Lights: шаг 4, изображение 1 из 1
    • Once the four connections are soldered securely, plug in the strip and turn the lights to all three colors to ensure that the connections are steady. Now you may place the lights where so desired.
    • If the strips had an adhesive backing, some new adhesive material may be required.
Заключение
A solder and soldering iron are fairly common and easy to acquire at a hardware store. Extra length of lights may be left over from initial use, use these first before buying more in order to lower costs; be sure you only cut the lights for repair where these 4 pads are they are likely marked by a dotted line across them, this is also where you'll solder them together. In order to put the lights back where they originally were, some form of an adhesive agent may need to be utilized. On the rear side of connection spot you can glue a small piece of cardboard to hold them together.
16 человек успешно провели ремонт по этому руководству.
Jacob
Участник с: 03/12/21
459 Репутация
1 руководство автора
Команда
University of Memphis, Team S52-G14, Kim Spring 2021 Участник University of Memphis, Team S52-G14, Kim Spring 2021
UM-KIM-S21S52G14
1 член
Автор 7 руководств
7 Комментарии к руководству
I dont know why this tutorial is rated as difficult, it really isnt.
Andrea Sherville - Ответить
Totally agree with Andrea Sherville. This has to be rated easy-moderate as this really isn’t difficult at all.
S Lee - Ответить
Thet step 4 was just weird
Israel McGhee - Ответить
Huh, I needed this exact guide. That's nuts.
FarmYard Gaming - Ответить
El autor dice: Si la soldadura no es una habilidad con la que estés familiarizado, primero debes consultar otra guía sobre los conceptos básicos de la soldadura. Se llama [guía|750|“Cómo soldar y desoldar conexiones”.] el autor no leyó esa guia la soldadura del paso 4 parecen cagadas de paloma
eamig - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 56
За последние 7 дней: 439
За последние 30 дней: 1,988
За всё время: 152,498
