How to Repair USB Fairy Lights
Выберете то, что вам нужно
  1. How to Repair USB Fairy Lights, How to Repair USB Fairy Lights: шаг 1, изображение 1 из 1
    • Identify the damaged part of the fairy lights and ensure they are disconnected from the USB with no current flowing.
  2. How to Repair USB Fairy Lights: шаг 2, изображение 1 из 1
    • Use a wire cutter to remove the coating from the broken ends of the wire, stripping about 1 cm (approximately the length of your fingernail).
    • Utilizing scissors and/or knives is also acceptable to achieve this step.
  3. How to Repair USB Fairy Lights: шаг 3, изображение 1 из 1
    • Ensure the naked wire is exposed and free from the coating, allowing you to work with the soldering iron without interference.
  4. How to Repair USB Fairy Lights: шаг 4, изображение 1 из 1
    • Use a nail file or sandpaper to sand the ends of the wire to remove impurities, then twist each end of the wire.
  5. How to Repair USB Fairy Lights: шаг 5, изображение 1 из 1
    • Preheat the soldering iron to 300 degrees Celsius.
    • The soldering iron will be very hot; make sure your workspace is clear of clutter.
    • Usage of safety goggles is highly recommended to protect your eyes from the resulting fumes.
  6. How to Repair USB Fairy Lights: шаг 6, изображение 1 из 2 How to Repair USB Fairy Lights: шаг 6, изображение 2 из 2
    • Bring the soldering wire close to the broken ends and start melting it using the iron.
    • Continue the process until the solder connects them securely.
  7. How to Repair USB Fairy Lights: шаг 7, изображение 1 из 1
    • Turn on the fairy lights to see if they glow.
Заключение
By following these steps, you should be able to repair your fairy lights and enjoy their glow once again.
Maher Kazi
Участник с: 07/04/24
145 Репутация
1 руководство автора
Команда
York University, Team 1-18, O'Regan Summer 2024 Участник York University, Team 1-18, O'Regan Summer 2024
YORK-O'REGAN-SU24S1G18
1 член
Автор 1 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 38
За последние 30 дней: 146
За всё время: 898
