Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
Tilt the opening pick to lift the rear panel a little bit.
There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
Remove the rear panel.
Remove the ten 3.6 mm Phillips screws that secure the midframe.
Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
Make sure all the clips are free.
Carefully remove the midframe.
Use the flat end of a spudger to pry up the rear-facing camera connector from the motherboard.
Carefully remove the rear facing camera.
Use the flat end of a spudger to pry up the front-facing camera connector from the motherboard.
Carefully remove the front-facing camera.
After completing the preliminary teardown task you will need to carefully remove metal covers on front and back of the motherboard with your knife.
They simply unclip and clip back in.
Clean entire board with your Alcohol, making sure all water has been cleaned and all corrosion is gone after alcohol dries.
Continue cleaning any water within device as well as all connectors.
Take the screen portion only and place it in your oven/toaster oven that can stay at a constant 140-150F for 2hrs. This will evaporate any water behind the screen that you cannot reach with your alcohol.
9 участников успешно повторили данное руководство.
9 Комментариев
Where is the microphone located at? Mine was water damaged and it works fine except for the microphone is very low. Thanks in advance for your help
If you look at the bottom of your Nexus 5x you will see a pin hole that allows the microphone to receive your voice. The microphone component will be right above that small hole. Unfortunately, I believe that the microphone component itself is soldered to the motherboard. You may be able to clean it more with alcohol and try again after it dries. Buying a new microphone and soldering on the new one would require a special soldering iron and almost expert skill. If you could purchase one with a broken screen for a reasonable price you could replace your whole motherboard with ease
My nexus 5x was water damaged about 3 months ago.If follow this process ,is it possible to recover it?
Did you tried it? I want to give it a go, if it’s still possible, but its broken about half a year.
My phone is not working it was fine till morning phone automatically switched off tried 1000 times its not working.
