How to Repair a Torn Seam in your Patagonia Clothing
Выберете то, что вам нужно
  1. How to Repair a Torn Seam in your Patagonia Clothing, How to Repair a Torn Seam in your Patagonia Clothing: шаг 1, изображение 1 из 2 How to Repair a Torn Seam in your Patagonia Clothing, How to Repair a Torn Seam in your Patagonia Clothing: шаг 1, изображение 2 из 2
    • Examine the damaged seam in your garment, checking for tears and removing any loose threads.
  2. How to Repair a Torn Seam in your Patagonia Clothing: шаг 2, изображение 1 из 3 How to Repair a Torn Seam in your Patagonia Clothing: шаг 2, изображение 2 из 3 How to Repair a Torn Seam in your Patagonia Clothing: шаг 2, изображение 3 из 3
    • Flatten out the garment around the torn seam, and align the fabric where the seam used to be.
    • Pin the two layers together. Be sure to catch only the two layers of fabric you wish to sew back together.
  3. How to Repair a Torn Seam in your Patagonia Clothing: шаг 3, изображение 1 из 3 How to Repair a Torn Seam in your Patagonia Clothing: шаг 3, изображение 2 из 3 How to Repair a Torn Seam in your Patagonia Clothing: шаг 3, изображение 3 из 3
    • Open the garment as much as possible, laying the seam flat.
    • Check your alignment and make sure the two edges of your fabric line up.
    • Put the garment in the machine, starting a few inches before the torn seam to overlap with the stitches.
    • Drop the presser foot. Align the first line of stitches with the needle.
  4. How to Repair a Torn Seam in your Patagonia Clothing: шаг 4, изображение 1 из 2 How to Repair a Torn Seam in your Patagonia Clothing: шаг 4, изображение 2 из 2
    • Use the balance wheel to sink the needle into the fabric.
    • Only turn the balance wheel in the direction that advances the machine. Turning the wheel the opposite direction can cause tangling or ruin the tension on the machine.
  5. How to Repair a Torn Seam in your Patagonia Clothing: шаг 5, изображение 1 из 2 How to Repair a Torn Seam in your Patagonia Clothing: шаг 5, изображение 2 из 2
    • Sew along the first line of stitches, removing the pins before you get to them.
    • If you run over the pins, you risk breaking your needle.
  6. How to Repair a Torn Seam in your Patagonia Clothing: шаг 6, изображение 1 из 2 How to Repair a Torn Seam in your Patagonia Clothing: шаг 6, изображение 2 из 2
    • When you come to the end of the row of stitches, engage the backstitch function of your machine. Backstitching prevents the seam from unraveling.
    • Backstitch functions vary widely between machines and can come in the form of buttons, levers, and knobs. See your sewing machine manual for instructions on your backstitch function.
    • Depress the pedal slowly. Sew two or three stitches backwards. Release the pedal and disengage the backstitch function.
  7. How to Repair a Torn Seam in your Patagonia Clothing: шаг 7, изображение 1 из 2 How to Repair a Torn Seam in your Patagonia Clothing: шаг 7, изображение 2 из 2
    • After you've completely sewn over the torn seam, clip the threads and free the garment from the machine.
  8. How to Repair a Torn Seam in your Patagonia Clothing: шаг 8, изображение 1 из 3 How to Repair a Torn Seam in your Patagonia Clothing: шаг 8, изображение 2 из 3 How to Repair a Torn Seam in your Patagonia Clothing: шаг 8, изображение 3 из 3
    • Some clothes have two rows of stitching, If your garment does, reposition it in the sewing machine. Drop the needle into the second line of stitches at about where you began sewing your previous seam.
    • Repeat steps 3-7 of this guide to resew the second line of stitches.
    • You do not need to pin this seam, because the first seam will hold the garment in place.
    • If your garment only has a single line of stitches, skip this step and proceed to the next step.
  9. How to Repair a Torn Seam in your Patagonia Clothing: шаг 9, изображение 1 из 1
    • Check that your stitches are straight and secure.
    • Admire your work.
Финишная черта
2 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 03/05/12
89 014 Репутация
Автор 131 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
Один комментарий
You will want to put the pins in (if possible to catch all layers) perpendicular to the seam you are sewing. Then you can sew right over them without breaking your needle. Plus you will not poke yourself as they come at you in the line of travel!
AMY - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 34
За всё время: 7,329
