How to Replace Blu Studio Selfie Microphone
Выберете то, что вам нужно
  1. How to Replace Blu Studio Selfie Microphone, Rear Cover: шаг 1, изображение 1 из 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. How to Replace Blu Studio Selfie Microphone: шаг 2, изображение 1 из 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. How to Replace Blu Studio Selfie Microphone, Battery: шаг 3, изображение 1 из 2 How to Replace Blu Studio Selfie Microphone, Battery: шаг 3, изображение 2 из 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
  4. How to Replace Blu Studio Selfie Microphone, Midframe: шаг 4, изображение 1 из 1
    • Remove all the 4mm Phillips #000 screws from the midframe.
  5. How to Replace Blu Studio Selfie Microphone: шаг 5, изображение 1 из 1
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. How to Replace Blu Studio Selfie Microphone: шаг 6, изображение 1 из 1
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
  7. How to Replace Blu Studio Selfie Microphone, Microphone: шаг 7, изображение 1 из 2 How to Replace Blu Studio Selfie Microphone, Microphone: шаг 7, изображение 2 из 2
    • Remove three 4 mm Phillips #000 screws holding the motherboard in place.
    • Carefully lift the motherboard from the phone, exposing the microphone soldering connections.
  8. How to Replace Blu Studio Selfie Microphone: шаг 8, изображение 1 из 2 How to Replace Blu Studio Selfie Microphone: шаг 8, изображение 2 из 2
    • Use a soldering iron to desolder the microphone from the phone.
    • Learn more about soldering here.
Заключение
2 участников успешно повторили данное руководство.
Stacy Kam
Участник с: 01/20/16
630 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 10-1, Remmell Spring 2016 Участник USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 431
