How to Safely Discharge a Capacitor
Выберете то, что вам нужно
  1. How to Safely Discharge a Capacitor, How to Safely Discharge a Capacitor: шаг 1, изображение 1 из 3 How to Safely Discharge a Capacitor, How to Safely Discharge a Capacitor: шаг 1, изображение 2 из 3 How to Safely Discharge a Capacitor, How to Safely Discharge a Capacitor: шаг 1, изображение 3 из 3
    • Capacitors come in various shapes and sizes, but the large cylindrical capacitors typically are the ones that store enough energy to be potentially dangerous.
    • Aluminum and Tantalum Electrolytic capacitors can pack a lot into a relatively small volume. They’re well suited to high-voltage applications because of their relatively high maximum voltage ratings.
    • Aluminum electrolytic capacitors, the most commonly used for high voltage, usually look like little tin cans, with both leads extending from the bottom.
  2. How to Safely Discharge a Capacitor: шаг 2, изображение 1 из 2 How to Safely Discharge a Capacitor: шаг 2, изображение 2 из 2
    • Identify all the capacitors in your device.
    • Locate where the capacitor's cathode will be by finding the side of the capacitor marked with a "-" (minus) symbol. This side will correspond to the negative lead, or cathode.
  3. How to Safely Discharge a Capacitor: шаг 3, изображение 1 из 2 How to Safely Discharge a Capacitor: шаг 3, изображение 2 из 2
    • Flip the circuit board over to access the capacitor's leads.
    • Avoid touching any metal when handling your electronics. Before being safely discharged, circuit boards may contain excess energy that can be dangerous.
  4. How to Safely Discharge a Capacitor: шаг 4, изображение 1 из 2 How to Safely Discharge a Capacitor: шаг 4, изображение 2 из 2
    • Touch the black, or negative, tip of the discharge pen to the capacitor's cathode.
    • This is the lead that you previously identified with the minus symbol on the side of the capacitor.
    • Touch the red, or positive, tip of the discharge pen to the other lead, the capacitor's anode.
    • Do NOT connect the positive and negative terminals of the capacitor together with standard wire, screwdrivers or wrenches as this will damage the capacitor and could cause bodily harm to the user.
  5. How to Safely Discharge a Capacitor: шаг 5, изображение 1 из 2 How to Safely Discharge a Capacitor: шаг 5, изображение 2 из 2
    • Watch the LED indicator on your discharge tool. If there is still a charge in the capacitor, the LED should glow red until the capacitor is fully discharged.
    • Once the light is no longer on, your capacitor is fully discharged and safe to handle.
Заключение
Your capacitor is now safe to be handled, shock free!
50 человек успешно провели ремонт по этому руководству.
Corey Brown
Участник с: 06/24/16
9 304 Репутация
Автор 11 руководств
1 Комментарий к руководству
Thanks a lot for the cool tips
prince - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 88
За последние 30 дней: 435
За всё время: 59,304
