Введение
Mustard from that corn dog. Your dripping morning coffee. Toothpaste. Stains happen! Many people believe that once a garment has a spot on it, it's time for the wash—but this isn't always true. By spot-washing and re-wearing your garments, you create less wear-and-tear on your clothes and the environment.
This guide will walk you through the process of washing a spot out of a garment. Have a tricky stain? Check out our Stain Removal page for the proper cleaning agent.
Инструменты
Запчасти
Детали не указаны.
Examine the stain. Determine what cleaning agent you'll need using our Stain Removal page. For general dirt, use a gentle, low-chemical liquid laundry soap.
Hold the garment over the sink and rub a small amount of your cleaning agent into the stain with your finger.
Using a toothbrush, gently work the cleaning agent into the stain.
Use an up-and-down motion with the brush—tapping the stain with the bristles—as opposed to a back-and-forth motion which can damage the fibers of the garment.
Work the stain out of the garment. If the stain isn't releasing, check out the Stain Removal page for help on your particular stain.
Lay a towel out on a waterproof surface.
With the wet area facing up, place your garment on the towel and allow it to dry.
6 участников успешно повторили данное руководство.
Один комментарий
Senate Cleaning is committed to providing clients with the best office cleaning services in Maryland, Washington, and northern Virginia areas. Through our skillful approach to office cleaning ensures that you will always receive the best value for your money with 100% satisfaction guaranteed
