How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance
Выберете то, что вам нужно
  1. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance, Battery Pack: шаг 1, изображение 1 из 1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 2, изображение 1 из 2 How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 2, изображение 2 из 2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 3, изображение 1 из 1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
  4. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance, How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 4, изображение 1 из 1
    • Begin by removing the rear particle bin.
  5. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 5, изображение 1 из 1
    • Next, locate the three screws on the iRobots hubcap/wheels. (You only need to unscrew one side)
  6. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 6, изображение 1 из 1
    • Using a Phillips Head screwdriver, remove all three screws on the side of the hubcap of the wheel.
    There are actually 4 screws holding the hubcap on. To get to the 4th screw, you need to loosen the top cover by removing all its screws. Note different lengths of screws.
    Albert Jeans - Ответить
    yes found that out during this operation
    MaryAnne - Ответить
  7. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 7, изображение 1 из 1
    • Gently slide the hubcap up and out of the wheel well of the Roomba.
    I have a fourth screw well up into the body on the hub cover. ~2.5cm into the body from the round hub outer circle.
    Ben Carr - Ответить
  8. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 8, изображение 1 из 1
    • Notice the wires attached to the hubcap. These are directly connected to the optical encoder.
  9. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 9, изображение 1 из 1
    • Using a can of compressed air, gently spray and clean the optical encoder until the dust had been removed.
  10. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 10, изображение 1 из 1
    • Using a screwdriver, gently remove the drive belt from the gear. This is the rubber band wrapped around the gear shaft.
  11. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 11, изображение 1 из 1
    • Slowly lift the gear from the gear shaft. Make sure you do not lose the drive belt.
  12. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: шаг 12, изображение 1 из 1
    • Thoroughly clean the exposed area of the wheel using either compressed air or a moist cotton swab. Be mindful of the exposed inner drive shaft when cleaning the wheel area to prevent any preexisting dust from entering the drive shaft.
    my hubcaps have 4 screws. it makes it muh more difficult.
    Don Paulgaard - Ответить
Заключение
4 участников успешно повторили данное руководство.
Christian
Участник с: 10/06/10
263 Репутация
1 руководство автора
Команда
Cal Poly, Team 20-7, Maness Fall 2010 Участник Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 членов
Автор 7 руководств
4 Комментариев
Thanks for your advice. I cleaned the sensors on the wheels and still the unit was having a circular dance. From another site mentioning another model there could be a problem with the sensors behind the front bumper bar and yes that was the problem. They needed blowing out with a strong air gun. Now after extensive cleaning my Roomba is running like a dream :-)
photofil - Ответить
My problem as well with my Roomba scheduler. The black and white front wheel housing was packed with rug fiber. Cleaned it out and all is well.
Also have a roomba discovery. It has a different front wheel with out any apparent sensor.
Will Long - Ответить
I have a roomba4100 it will turn on it will try to go but will stop after 1second don't know what's wrong could it be the belt
Rodney - Ответить
I have a Roomba from 2002 (before the 400 series. This tutorial looks like it might apply, but I can only get 2 of the 3 screws off the hubcap of the wheel. The other one is blocked by the top cover.
Stephen Martinson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 14,570
