How to open the SteelSeries Nimbus+ Controller
Выберете то, что вам нужно
  1. How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: шаг 1, изображение 1 из 2 How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: шаг 1, изображение 2 из 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. How to open the SteelSeries Nimbus+ Controller, Remove the sticker: шаг 2, изображение 1 из 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. How to open the SteelSeries Nimbus+ Controller, Unscrew the back cover: шаг 3, изображение 1 из 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: шаг 4, изображение 1 из 2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: шаг 4, изображение 2 из 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: шаг 5, изображение 1 из 2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: шаг 5, изображение 2 из 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: шаг 6, изображение 1 из 2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: шаг 6, изображение 2 из 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: шаг 7, изображение 1 из 2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: шаг 7, изображение 2 из 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: шаг 8, изображение 1 из 3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: шаг 8, изображение 2 из 3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: шаг 8, изображение 3 из 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: шаг 9, изображение 1 из 3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: шаг 9, изображение 2 из 3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: шаг 9, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. How to open the SteelSeries Nimbus+ Controller, Remove the back cover assembly: шаг 10, изображение 1 из 1
    • Remove the back cover assembly.
Заключение
Еще один человек закончил это руководство.
Adriana Zwink
Участник с: 12/18/19
61 760 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 608 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 33
За всё время: 1,808
