How to replace the main PCB
Выберете то, что вам нужно
  1. How to replace the main PCB, Remove the screws: шаг 1, изображение 1 из 1
    • Unscrew the four screws of the metal plate underneath the Warthog.
    Спросите у FixBot
  2. How to replace the main PCB, Remove internal screws and cables: шаг 2, изображение 1 из 2 How to replace the main PCB, Remove internal screws and cables: шаг 2, изображение 2 из 2
    • Carefully remove the four screws displayed on the picture.
    • Disconnect the two cables displayed on the picture by making sure to not damage them. A pair of flat pliers might be recommended.
    Спросите у FixBot
  3. How to replace the main PCB, Unsolder the PCB: шаг 3, изображение 1 из 1
    • Using a soldering iron, remove the previous PCB and replace it with the new one.
    • Once that is done, reassemble the product.
    Спросите у FixBot
  4. How to replace the main PCB, Update the firmware : open the updater: шаг 4, изображение 1 из 2 How to replace the main PCB, Update the firmware : open the updater: шаг 4, изображение 2 из 2
    • You will then need to update the firmware of the new PCB. To do that, connect the Magnetic Base (with a joystick on it) to your computer.
    • (First picture) If you have not already, download and install the driver of the product available on Thrustmaster support : https://support.thrustmaster.com/en/prod...
    • (Second picture) Open the "Firmware Updater". To do that, write "Firmware Updater" in the Windows search bar, the open the software.
    Спросите у FixBot
  5. How to replace the main PCB, Update the firmware: шаг 5, изображение 1 из 3 How to replace the main PCB, Update the firmware: шаг 5, изображение 2 из 3 How to replace the main PCB, Update the firmware: шаг 5, изображение 3 из 3
    • (First picture) Your device appears in the firmware updater. Apply the update by clicking on "OK".
    • (Second picture) The update is in progress.
    • (Third picture) The update is done ! You can close the firmware updater by clicking on the arrow at the top right corner.
    Спросите у FixBot
  6. How to replace the main PCB, Calibration - Getting the software: шаг 6, изображение 1 из 3 How to replace the main PCB, Calibration - Getting the software: шаг 6, изображение 2 из 3 How to replace the main PCB, Calibration - Getting the software: шаг 6, изображение 3 из 3
    • (Picture 1) Finally, you need to recalibrate the device. Thrustmaster has made this tool available here: https://nextcloud.guillemot.fr/index.php...
    • (Picture 2) Extract the archived file on your computer.
    • (Picture 3) Launch the calibration software.
    Спросите у FixBot
  7. How to replace the main PCB, Calibration: шаг 7, изображение 1 из 1
    • The calibration software will detail all the steps to follow. Make sure your Warthog Stick is connected to your computer, with a compatible joystick mounted on it.
    • Once you have fully followed all the steps of the calibration tool, you are done !
    Спросите у FixBot
Заключение
SarahK
Участник с: 08/16/24
145 Репутация
1 руководство автора
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 34
За всё время: 468
