Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Put on the shirt.
Pull the strap up until you reach your new desired length. Be sure to take the same amount of fabric from the front and the back of the seam.
Pin both straps to the desired length.
Remove the shirt.
Measure and take a note of the length. Make sure it is the same on both straps.
Remove the pins and flip the shirt inside out.
Re-pin both shirt straps. Make sure the pins follow the measurements you just took.
Make sure you have a clear line to sew along.
Check and make sure the base of the straps are lined up for a continuous edge on your shirt.
Thread the sewing machine and set it to your desired stitch length.
Align the pinned part of the shirt with the needle.
Put down the presser foot.
Sew along the line mapped out by your pins.
Pull out the pins as you sew. Make sure not to sew over any of them.
Make sure to backstitch at each end of the seam.
Repeat this step for each strap.
Put the shirt back on.
Confirm the new length that you chose for the garment.
If the straps are too still long or short, carefully rip out your new seam and return to Step 1.
Cut excess fabric from the new seams, leaving ¼ inch to ½ inch.
Iron the seam allowance left after your cut to the back of the shirt.
Flip the shirt right side out.
Make a straight stitch approximately 1/8 inch behind the new shoulder seam on the outside edge.
2 участников успешно повторили данное руководство.
