Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
battery disconnect huawei mate 9 - prereq only
Выберете то, что вам нужно
Carefully peel off the plastic sticker that holds both cables to the battery.
Remove the water indicator sticker and the Phillips #00 screw beneath it, that holds the cable bracket in its place.
Use a spudger to disconnect the interconnect, the battery and the display flex cable.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
