Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
Carefully pry the display with its parts out of the case.
After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Swing open the phone backwards.
Use a spudger to disconnect the power- and volume button flex cable.
Remove the Phillips #00 screw.
Use tweezers to remove the metal plate.
Use a spudger to disconnect the battery flex cable.
Remove the four Phillips #00 screws.
Use Tweezers to remove the metal plate.
Use a spudger to disconnect the main flex cable.
Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
Use a spudger to pry out the charging board.
Remove the charging board.
14 участников успешно повторили данное руководство.
4 Комментариев
Just remember to take off a tape from the microphone on a new piece. I had to open mine twice
If you have problems on connecting the cable to the charging port, before considering replacing the charging board, try removing the dust that may be occluding the port. Use tweezers to remove the dust and try if the cable connects. Do it carefully as your could damage the pins.
Second the above comment! - If you are having trouble fully inserting the USB cable, then try remove the dust with a pair of fine tweezers.
I recently changed the battery of my P10 but the phone always died when the brandnew battery was still at 50%. It is no battery calibration issue - over the next ten days it got worse, died at 70%, now it frequently dies at 90%. The phone only starts with charging cable plugged in, then the battery charges from 90% to 100% in roughly one hour, but the "charged" battery only lasts about an hour or less, the phone dies when it reaches 90%. Looks to me like fake charging (or rather fake uncharging?). Is someone familiar with such an issue? Was the new battery defect from store? Or is the charger defect? The phone runs fine with power cable plugged in. Can it still be the charging board? Should I try the replacement shown in this article?
